1 members (RLB), 92 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#10744 04/09/2004 12:01 PM
All,
Hope to change the trany, transfer case and diff fluids this weekend in my 69 Chev C10 4x4. Any negative (or positive) comments regarding the use of synthetic oils (Amsoil)?
Rememended weights?
Thanks All!
Joe S.
69 Chevy C10 4x4
69 Mercedes Unimog 404
#10745 04/09/2004 12:53 PM
We changed the 4 speed transmission's lube in Dad's **** to Amsoil many years ago. What a difference!!!
In the real cold, which Northern Minnesota tends to get, you could still push the truck around by hand, where the old stuff got so solid yo could hardly move it at all. It was hard starting out before the change, but much easier after. I can't help but think the mileage is better.
We're approaching 20 years later now, and my brother is still beating on the truck. Not bad for a late 70's **** . wink
Be sure you have good seals and the breathers are clean. You don't want that expensive stuff leaking out.
Fred
52 3600
69 C-10
#10747 04/10/2004 10:58 AM
I run Valvoline Syntech 20W50 in the 350 V8 in my '71 Jimmy. It seems to run smoother than the organic oil. I just changed oil yesterday, and I realized I had run it for more than 5000 miles. About twice what I intended to go for. It was dirty but had not broken down. It ran a lot better with fresh oil, though.
Every 25 years I like to rebuild that 292 just for GP
#10748 04/10/2004 11:46 PM
Not sure what your transfer case would take but use the Amsoil Series 2000 75w90 in the front and rear axels. Ask your amsoil guy the get the books out.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#10749 04/12/2004 11:51 PM
Did the manual trans Saturday and what a big difference, much smoother shifting.
Used Amsoil 75-90w gear oil.
Will attack the diffs this weekend.
BTW, I am still looking for a tailgate.
Thanks!
Joe S.
69 Chevy C10 4x4
