8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible), 57 guests, and 4 robots.
Topics128,075
Posts1,055,919
Members48,429
Can someone tell me. The proper no Of shims that go between the radiator cire support and the front cross member ? Also are they all metal or is there a leather shim included?
1950 3100 radiator?
earlier mounting pad
50-55 mounting pads
Metal shims (of different thickness and numbers) are used between radiator-mount pad and frame to help align body parts (alignment of fenders, hood, grill to cab - if necessary.
Thanks for the information Tim. I have a47-49 core support. That I'm planning on using with my 50 burb. This burb started out on s gmc frame when I bought it. I changed the front cross member to a chevy cross member snd have a 47-49 core support. As you can see it's a conglomeration of parts. I'm hoping that it will come together and work with my Chevy sheet metal.
Check the fender-to-cab body line gap. If it's tapered from top to bottom, add or remove shims to help align the front sheet metal with the doors. Typical bodywork- - - - -if it looks good it IS good, no matter what needs to go on under the skin to make the sheet metal fit. Don't try that approach inside an engine!
Thanks Jerry. I'll try your approach.
