| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Can someone tell me. The proper no Of shims that go between the radiator cire support and the front cross member ? Also are they all metal or is there a leather shim included? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1950 3100 radiator? earlier mounting pad 50-55 mounting pads Metal shims (of different thickness and numbers) are used between radiator-mount pad and frame to help align body parts (alignment of fenders, hood, grill to cab - if necessary. | | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Thanks for the information Tim. I have a47-49 core support. That I'm planning on using with my 50 burb. This burb started out on s gmc frame when I bought it. I changed the front cross member to a chevy cross member snd have a 47-49 core support. As you can see it's a conglomeration of parts. I'm hoping that it will come together and work with my Chevy sheet metal.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Check the fender-to-cab body line gap. If it's tapered from top to bottom, add or remove shims to help align the front sheet metal with the doors. Typical bodywork- - - - -if it looks good it IS good, no matter what needs to go on under the skin to make the sheet metal fit. Don't try that approach inside an engine! Jerry
| | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Thanks Jerry. I'll try your approach. | | |
