0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 6 New Guy | | New Guy Joined: Dec 2014 Posts: 6 | Hi Guys, I got a used OE 4 Barrel Intake Manifold from a 1960's 283 engine.......AND...... I got a newer Edelbrock 600 CFM carb. laying around also. My Question: Has anyone ever tried to remove the plenum dividers ( the area underneath where the Rochester Carb. sits ) on the intake manifold on a Drill Press / Milling machine or a cut off blade and grinder ? So that the newer Edelbrock Carb. fits the old style intake, like a new Edelbrock Open Plenum Design Intake ? Have I explained what I want to try correctly ? Just wondering if anyone has tried it before and if it would work. Trying to use some parts that are laying around. No sense spending money on new parts if I can make the old ones work somehow.
Thanks.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You can buy an adapter to make it work, I don't think that modifying the original intake would give very good results at all. I'm assuming that the intake you have has the smaller holes and they look kind of like a figure 8. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | You will ruin a perfectly good manifold. Either get a carb that will fit the manifold, or a manifold designed for the carb you have. Eliminating the divider between the planes of a dual plane intake will have no good results, and possibly a BUNCH of bad ones.
Unless you're planning to run the engine above 3,000 RPM most of the time, there is no advantage whatsoever in combining the flow from both sides of the carburetor. If you DO plan on running wide open most of the time, a stock 283 dual plane manifold will be about as worthless as a screen door in a submarine. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Save time - just throw it away. | | | | | Joined: Dec 2014 Posts: 6 New Guy | | New Guy Joined: Dec 2014 Posts: 6 | Thanks everyone for your honest replies. I love it !
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Save time - just throw it away. The 283? The Intake? The Carburetor? Cynicism is only effective if used in a specified manner. Otherwise it just comes off as rude, and I am sure that rudeness was not your aim. Carl
