Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Wickedbass, 55shaker), 38 guests, and 2 robots.
Topics128,009
Posts1,055,297
Members48,419
#107348 08/05/2004 10:03 PM
I am installing a NOS visor on my 1954 3104. Appears all brackets are present and accounted for but no attaching hardware. First, what types of hardware was used (sheet metal screws? bolts?) and does anyone know a source for the hardware.
thanks
My rule of life: You can have anything you want; you just can't have everything you want.
#107349 08/06/2004 12:01 AM
The hardware is pretty basic...1"X 1/4 by 20 thread carriage bolts and nuts (two (2)end connectors. The screws are 1/4" - 1/2"...the vertical adjustment is 2 screws (one on each side)I used a clip to secure them. The middle brackets take two (2)screws...I have the originals and they have an odd clutch-head nut...but I think a regular ss nut would work.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#107350 08/06/2004 3:22 AM
The hardware described in the previous reply does not appear to apply to the orginal 54 visor. My visor has 3 sheet metal screws on each side bracket where they attach to the drip rail channels. The triangular center bracket that attaches to the roof I attached with three larger sheet metal screws directly into the roof skin, which is incorrect according to the factory accesory installation manual but it worked for me.
By the way I am the guy that was bothering you and your wife at Kimball Park last sunday. If you need a copy of the installation instructions I would be more than happy to fax them to you.
#107351 08/06/2004 3:36 AM
I forgot to mention that the screws are stainless steel and I bought them from the bolt vendor at Pomona. I need to correct my previous post, the side brackets attach to the roof behind the drip channel. Once again if you need the install instructions, just let me know.
#107352 08/06/2004 3:41 AM
Quote
#107353 08/06/2004 3:43 AM
[QUOTE]Originally posted by 54-me:
[/Could really use the instructions. I believe you have my card. Never a bother talking to a fellow 54 fan.]
#107354 08/06/2004 3:52 AM
Yes, I have your card. I will fax it to you from work first thing tommorrow morning.
#107355 08/06/2004 5:10 AM
54-me
Will you also fax the instructions to me. I do not think my visor is install properly. I would like to check it.
Fax to: Attn: Lonnie 909-864-0653
Lonnie
#107356 08/07/2004 3:30 AM
Lonnie, I will fax it tommorrow morning.
#107357 08/15/2004 1:36 AM
External visor is what everyone is talking about.
#107358 08/16/2004 5:41 PM
54-me
Thanks for the info. As I thought my visor is not installed properly. It is installed on the drip rail like most visors I have seen.
#107359 08/16/2004 9:17 PM
OK, I will once again show my ignorance.
Just to be careful, is everyone talking about a NOS Chevrolet (windshield) visor? Fulton made a visor and this was a very common aftermarket accessory. Are the Chevy and Fulton (and GMC) visors attached the same way in 1954?
Tim
#107360 08/17/2004 3:35 AM
The visor we are talking about is the genuine chevrolet accesorie visor for 1954. The Fultons I have seen use a different type of mounting system. Lonnie, I nearly made the same error of mounting mine to the outside of the drip channel because I had seen a couple of trucks like this. Good thing I found the installation instructions before any drilling.
#107361 11/30/2004 10:05 PM
Hi 54-ME, could you post or send me some pictures I like to get one for my 1954 but like to see how it looks. Thanks in ADvance Dutch. [email protected]
