| | | Forums66 Topics128,014 Posts1,055,331 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 53 chevy truck I'm putting my steering wheel back on does anyone know where the spring goes on the steering wheel . Is it steering wheel then horn contact then spring ? Does anyone have a assembly diagram ? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | See figure 2 at the bottom of the page. The spring goes under the steering wheel, and rides on the eat of the mast jacket bearing to provide preload on it. Without the spring in the proper spot, the upper steering shaft will be sloppy.
Bill Burmeister | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | Ok kool so slide the spring down the shaft then the wheel horn retainer and nut ? Is there a washer under nut I don't remember pulling on off .. | | |
