2 members (Otto Skorzeny, rfs56trk), 69 guests, and 3 robots.
Topics128,094
Posts1,056,487
Members48,444
#107320 12/16/2001 4:01 AM
Do you have to remove the cab in order to remove and install new floor pans?
thanks
#107321 12/16/2001 7:44 PM
52GMC, I think its better to do as much of the welding and work on the floor pans with the truck cab mounted to the frame to help support and keep everything in alinement. I figure on pulling my cab off after I get everything welded in to sand blast the underside and what not. I like to weld over the seams on the underside for added strength, then I can grind the weld on top down flush. smile
#107322 12/18/2001 1:32 AM
You mite also want to support the
front corners on the cab when you cut away
the floorpans, there isn't much left if your
removing the whole piece. I used a jackstand
and some pieces of board to shim to correct
hieght before cutting.
