| | | Forums66 Topics128,026 Posts1,055,404 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I think it may be an aftermarket add on for the 265 V8, and I doubt it would have been primed with orange, definitely repainted
Bill | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Thought possibly 265V8 also except after a search it does not have the correct mount for the V8 so still looking for help on an ID of it. Thanks.
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There were two styles of optional GM oil filters for the 265 (1955 version and 1956/57 version). Both look different from the filter in the first post. 1955 was a canister with hoses. It was mounted on the top right-front of the engine. This might have been a by-pass filter? https://dl.dropboxusercontent.com/u/30524403/265%20oil%20filter%20%24_57.JPG http://www.trifive.com/garage/55%20Chevy%20Assembly%20Manual/237-1-01.gif1956-57 was a spin-on metal canister that "spun onto" a head that was directly connected to the block (no hoses) - lower left year side of the engine. This might have been a full-flow system with a by-pass valve in the filter "head"/boss. https://dl.dropboxusercontent.com/u/30524403/265%201957%20oil%20filter%2019.jpghttp://www.567chevys.com/Images/ENGINE.JPGThe 56/57 265/283 came standard with a block-off plate for the optional oil filter (RPO 237). | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Tim, That's the image I found earlier as to eliminating my canister from that suggestion. Given the port locations on my canister, I am wondering if it is not AC/GM at all. Maybe Ford or Chrysler despite what the seller's tag read at the time. I was just getting into Chevy inlines at the time with little knowledge. Likely it was cheap though.
Drew
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Drew,
I posted that information in agreement with your comment regarding your filter most likely not being a GM filter for a 265 (or other early) GM V8.
There are many other possible sources of a by-pass oil filter. Sears, Montgomery Wards, and Western Auto were three large sellers of non-Auto maker oil filters.
It would be interesting to know what brand/make it is.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I wish I did knew the brand at least, but there are no imprint markings on the canister to help.
Drew
