9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 9 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 9 | I'm swapping out my split-rim wheels for modern steel rims on my '53 3600 pickup. I want to install the original hubcaps that require clips to be installed on the replacement steel rims. When I looked at wheel clips from Classic Parts, it indicated that they were for 1/2-ton trucks only. My question is whether or not I can use these for my 3/4-ton truck. Why would they be different? Thanks in advance! | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | I too have a 53 3/4 ton I had the wheels converted to take a radial tire. I bought new hubcaps and the clips to hold them. the hubcaps I got from classic parts, I can't remember where I got the clips ( either car and truck shop, obsolete chevy parts, the filling station or classic parts). I had to bend the clips to get them to hold the caps. in the end I used a couple of the original clips which were much more "stout" than the repop ones.
1963 c10 | | |
