| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | hi all I am seeking clutch size for a 265v8 all the books from truckshop LMC don't have size for 265 v8 merry xmas to all
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | According to the Shop Manual, it is 10" for 1/2 through 1 1/2 ton for both 6 and V8.
Bill Burmeister | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There were lots of options on clutch sizes. You have to measure it to be sure. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I recently replaced a clutch on what appears to be an original 55-2 with a V-8. It was an 11" unit. I wouldn't buy any parts until I removed it to be sure. Fred
| | | | | Joined: Jul 2012 Posts: 14 New Guy | | New Guy Joined: Jul 2012 Posts: 14 | I also have a 265 and it depends if it is a truck or a car motor the flywheel is different sizes found out mine is out of a Belair and it is smaller then a truck | | | | | Joined: Dec 2011 Posts: 112 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 112 | TPR57C I have had a few '57 3100's with 265/4 speeds, all are org and all had 11" clutchs. For what it's worth. delky dave in WYO
1957, 3100, v8 2016 gmc 4wd
| | | | | Joined: Jan 2012 Posts: 843 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 843 | Finally pulled clutch out 11 inch 10 spline worn out that much springs on clutch plate were rubbing on flywheel bolts
