3 members (Gray_Ghost, walter74, 1 invisible),
107
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 108 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 108 | Where do I find or what do I use on the INSIDE of the Windshield Frame to hold the glass in. I have checked with most of the after market places and they seem on only have the OUTSIDE FRAME TO BODY piece. Help! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Could you be more specific as to what year of truck? On the '47-up, the gasket fits over the pinch weld and holds everything in. Are you referring the the windshield frame of the earlier trucks?
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Jim Carter sells glass setting tape for roll-up windows and front windshield frames. Go to links at the top of this page, under parts. | | | | | Joined: Jul 2003 Posts: 108 'Bolter | | 'Bolter Joined: Jul 2003 Posts: 108 | Thanks, Its a 46 Chevy Truck. It was the "term" I was missing. Glass setting tape, instead of gasket, or rubber. Thanks | | |
