1 members (klhansen), 101 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
#1068719 11/17/2014 12:11 AM
What cartridge and where can I get one that will fit in the AC L-4 oil filter canister? secret
Thanks.
Harold
shake
Harold
It looks like a Wix51010 might fit. Same as a Ford Tractor. Check the measurements
Steve H
Steve,
Thanks, I will check it out.
Harold
Harold
Harold,
Don't know if you looked here or not. Lots of good info.
Dan
Steve,
Quote
I looked at the WIX web site loaded the P/N WIX51010 and got this reply:
There is no information available on the part number you submitted. I will take the canister into a parts house and check various filters. There must be one out there somewhere.
Harold
Harold
Tim,
Thanks. I never thought about Ebay.
Have you used this filter in the AC L-4 canister?
Harold
Harold
Harold,
I do not have that canister filter.
Sorry,
Brian
1955.2 3100 Truck
Brian,
Thanks I will check with them.
Harold
Harold
Still searching for a filter for the AC L-4 oil filter.
The WIX 51010 fits in the container but is about 1/4" too tall. The lid cannot go all the way down to seal.
Any other suggestions appreciated.
Harold
Harold
Harold,
Have you checked out this tech tip? Pat was helpful in setting me up with the correct housing/bracket for my project. I would bet he knows some interchange options off of the top of his head.
http://www.stovebolt.com/techtips/engines/oil%20filters/index.html
Paul
Lots more pictures
Paul,
Yes, he helped me ID the filter housing. I have sent him 2 emails regarding the filter element, 1 in Nov & another in Dec but have not received a reply. He must be busy.
Harold
Dec 5
Heard from Pat. He advised the original filter was a AC P-110 paper oil filter. I cannot find a cross reference for this number. Can anyone offer a solution?
Thanks Harold
Harold
I
I Offline
I have the same filter in my 47'. Just go to NAPA and tell them the filter number. They probaby have a direct replacement on the shelf.
Try the Wix WL7000 it might fit. Get the measurements, I would bet that NAPA has one that will fit.
Steve H
Steve,
I cannot find any info on the WIX WL7000. It does not show on the WIX site or any cross reference.
Do you have a site or another #?
The closest NAPA is 1 hour away. I tried to call but they were too busy to look it up in their records.
Harold
Harold
Tim,
Thanks for the links. The name has changed to KILLER FILTER. They must make it since the WIX site has no info on the WL7000.
I'm surprised Google did not cross reference this when searching for WL7000.
Thats what is good about the FORUM; there is always someone that can supply the correct info.
Harold
Harold
