1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
I can't find the spot on my 64 230ci motor where I can hook up the oil pressure sensor line for the gage. Where is it? Also, is there a spot on the motor close to the firewall where I can hook up the water temperature sensor? My 46 Chevy gage line won't reach the water neck or the plug on the head in front of the carb. Thanks
Oil sender location is on the block just above the starter. You might need to use a bit of 1/8 inch pipe to extend for a mechanical gauge line and a compression fitting.
http://s61.photobucket.com/user/Jho411/media/IMG_0608.jpg.html
Just above the starter and below the PCV in this picture.
The Temp sender is on the head on the driver side towards the back just about where the rear intake is located and above it. Plumbing fitting to adapt to the mechanical sender.
http://s31.photobucket.com/user/classicgmjunkie/media/three_singles.jpg.html
Follow the wire from the firewall that goes up and over the carb in this picture.
Steve H
