| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 13 Junior Member | | Junior Member Joined: Oct 2003 Posts: 13 | My 52 chev 3/4 needs new wing windows. The frames look ok, but the glass is broken. Can I buy the replacement windows? I have seen replacement windows that do away with the wings. Is this a good alternative?
Thanks Mike | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | At the top of this page, click on "Links."
Many vendors sell replacement glass for AD's, along with the rubber seals and miscellaneous hardware. Be careful when installing the new glass, it will try to seat too far into the frame (old age, rust expansion, etc.) and leaves a gap between the glass and vertical "cat whisker" strip.
edit: Most of those "wingvent delete" doors are actually earlier doors that didn't come with wing windows. Conversions are expensive and time consuming, requiring metal fab in tight areas. Much easier to go to the junkyard. | | | | | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | The doors are not the same the early ones had one piece of glass. I have 6 doors from a bulk deal. 10 bucks a door. The doors with one peice have turn down handles. Chevy Duty cataloge gives a good description of all the AD's O | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | You can get new, completely assembled units ... chrome or not ... HERE
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Dec 2002 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 50 | I had the wings and door glass done at a local windshield shop. glass installed in frame $30 for the wings and $35 for the door. You might want to try a shop before you order your glass. Greg
1951 1.5 ton 4400 | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Originally posted by OldCarKook: Alan: BowTie Bits wing vent is a restored part, not a new part. No one is remanufacturing these wing vent assemblies new as far as I know. My mistake ... I knew that -- what I meant was, they're LIKE new jobs!
