| | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 12 New Guy | | New Guy Joined: Oct 2014 Posts: 12 | I bought a Vintage Air Gen2 heater defrost unit for my '52 3600. The truck is still 6 volt, and although I plan on converting to 12V, I can't during winter months because of lack of a garage to work in. My question is, can I use an 12v converter, which only goes as high as 15A, or will I have to have an auxiliary 12v battery just to power this heater? Or does anybody have any other ideas? I REALLY want to start driving this truck to work, 60 miles round trip, because it is a blast!
I hate new trucks! My menagerie: 1952 Chevy 3800 "Ol' Blue '52" 1979 Chevy C-10 "Ol' Red" 1968 Triumph T100R
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | The problem with a 6 volt system and a converter to 12 volts is the current limits. To get a dc to dc converter that would supply 15 amps would be some big dollars. You can run a Radio, I pod, GPS and other low power stuff but the fan motor will be too much load. It might be cheaper to convert to 12 Volt or buy a 6 volt fan motor. The conversion to 12 volts is rather simple. But it does mean lights, regulator if you go with a generator, Voltage reducer for the gas gauge and a ballast resistor for the coil and points. A battery will cost about 100 dollars so even that is not a cheap alternative. If you plan on converting any way, start getting the bits together and talk your way into a garage. Beer helps
Steve H
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The old 6 volt blowers take 8 amps max. The same output at 12 volts would be 4 amps. Now I know the vintage air blower would be powerful but where did the 15 A come from? Does it have an electric heater? | | | | | Joined: Oct 2014 Posts: 12 New Guy | | New Guy Joined: Oct 2014 Posts: 12 | The 15 amp is the converter, but the Vintage unit wants a 30amp fuse put inline to the battery, so I am sure it must draw more current than 15. Maybe I will just set a 12 volt battery on the floor, run the heater with that, and put it on the charger every night. Or just do without as I have the last two days I drove it to work!
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | 15A or 30A sounds way to high for a truck heater fan motor. Hook it up to a battery and try different fuses. Or if you have a current meter check. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | If you can't convert to 12 volts first, then maybe it would be easiest to slap a 6 volt heater in there for the winter. That would give you the winter to plan out the conversion, source parts and be ready for spring.
Dennis
40 Chevy 1/2 ton
