0 members (),
41
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I have a 66 suburban with a 292 in it. The alternator bracket that mounts on the drivers side of the block, down next to the oil pan, has 2 tabs that stick out for the alternator to mount to. The bolt fits the holes in the alternator, but the holes in the bracket are different sizes, and larger than the bolt. I assume that some kind of metal sleeve in a rubber bushing is used, but I can't find anything in the manuals or parts catalogs. Does anyone know what goes in there, and where I may find them. Thank you for your help. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I have a 1965 C10 and I parted out a 1966 C10. Both had brackets like you describe. I don't think that there is anything but a bolt through the bracket and alternator. It is meant to pivot on the bracket but once locked in place, it stays in that position and really should not move. If yours is different, then you could just use metal tubing inside the loose piece to create a bushing. I suspect that it will not be needed. Can you post photos?
| | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Lugnutz, thanks for the reply. No, I don't have any pics, but I need to check to get more accurate info. Off the top of my head, it looks like a 5/16 bolt, and the holes in the bracket are say 1/2" and 7/16", just guessing. I took it apart about 3 years ago, and I don't see any other parts. The bracket is a cast stock appearing piece, not a fabbed up one. Normally you see a rubber mounted bushing on a generator, but not necessarily on an altenator. Thanks again. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The front mount bracket should be 3/8 in. The rear is larger & should have a sleeve that is a tight fit in the bracket hole. It slides in the hole to take up exsesive clearance between the alt & the brackets. The front hole could be wallered out from a loose bolt. It takes a long 3/8 bolt to go all the way through. The upper adjustement bracket bolt is 5/16 coarse thread. Some of the later models used a metric bolt near the same size. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Thanks for the input wrenchbender, I don't have time tonight, but tomorrow night I will take a closer look at it to make sure I'm on the right page. | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | This is a pretty decent view of my [size:11pt]lower alternator bracket[/size]. I just upgraded to a 1 wire alternator and used my 1965 factory brackets. | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | Well, I took a look at the bracket last night, and took some dimensions, and it agrees with what you guys have told me. A 3/8 bolt, the front hole is washed out, and the back hole is .515 dia. for the sleeve. So, I figured I would take it too work, bore out the front hole, press a bushing in it, and make a sleeve for the back hole. I put a pin gage in the big hole to align it against an angle plate, and that front washed out hole is no where close to being on the same centerline as the big hole. I double checked everything there, and then come home and checked the block, alternator, etc, to make sure nothing is skewed. Evidently, that is why there is no bushing in the back hole, just to get it to line up. Unless somebody knows something that I'm not seeing, we'll fix her. Thanks again for all of your help. | | |
