11 members (55shaker, Doug Boudreaux, Steveoreno, 1955 1 Series, Bill Trotter, dt235sd, Jethro in Va, 3B, Wingnut68, moparguy, Peggy M), 69 guests, and 2 robots.
Topics128,197
Posts1,057,400
Members48,471
Is the a really good reason not to use the front suspension from a chevy 1500 as opposed to the older
63 to 88 c10 front clip?
the 63 to 88 is hard to find around here the latter
1500 is fairly easy to find.
I'm putting it under a 51 3600 so it's a little different then the 3100 swap making a cross member isn't
really a problem for me.
I take it by Chevy 1500, you're talking about the 88-98 trucks? There's several issues with using that front end under an earlier truck. The first is , of course, the track width. It's going to be too wide for the earlier truck. The second problem, and really the main obstacle to using it, is how the suspension is integrated into the frame on the GMT 400 chassis. Unlike the earlier IFS trucks, the GMT 400 does not have a separate crossmember that the suspension mounts to, all of the suspension mounts are part of the frame. On the 2wd trucks, the upper control arms mount on top of the frame rail, 4x4s mount to the sides. In order to use the suspension, you would either need to use the entire front clip, or be very precise about transferring over the mounting points and welding them to the older frame.
However, there is another solution. I don't recall who makes it, but there is a company that makes a mounting kit where the AD body can be installed on a GMT 400 chassis. I believe they also make a kit that allows for the used of an Impala/Caprice chassis as well.
Bill Burmeister
Yes was thinking of using the 88-98 front end for a parts source
and building a new crosmmber with mounting points attached.
If it could be narrowed to the right track width and still match up to the frame.
now S10s are as common as dirt around here down side of that is they are alittle narrow and light for what I want.
Ideal size would be 1/2 ton suspension and brakes.
anyway it's done it seems like some fabrications will be needed
worst case for a crossmeber is have to draw it in Solidworks and have one of the locals water jet a piece of plate
