3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1070866 11/30/2014 7:25 PM
Can anyone tell me if it is possible to drop the oil pan and exchange the rod or main bearings?
I have a 55 series II pick up and it's beginning to make rattling noises above 2500rpm.
I'm new to this but it looks to me like there is a steering link that is in the way but once removed there should be enough room to drop the pan.
Don't really want to pull the engine and hope there is an easier way. Of course I'll measure the journals and look for damage before replacing anything.
Many Thanks
sepp #1070868 11/30/2014 7:43 PM
Depending on the year model of the 235, there may be dowel pins that help keep the main bearings in place. That may require lowering the crank more than those that just have a slight flange on one side to hold them in place.
You may have to drop the transmission and remove the timing cover to gain enough room to change them.
But maybe some one else will come along that knows more about that year model engine.
sepp #1070882 11/30/2014 9:16 PM
Rod bearing noises are pretty distinctive. With the truck parked, a momentary rev of the engine will bring out a rod bearing noise just as the RPM stops rising and before it falls. A main bearing produces a thud or a dull knock under load at low RPM. Both types of bearings can cause low oil pressure problems.
1951 1 Ton Completed
truckernix #1071025 12/01/2014 1:22 PM
Thanks for your quick reply. Next time I start my truck, I'll pay closer attention to when the noise occurs. Up til now, I only noticed it when driving and above 2500rpm. Nothing on start up although I could have overheard it.
I have NO OIL PRESSURE Problems. Pressure is excellent with or without the noise.
sepp #1071067 12/01/2014 7:04 PM
Try retarding the ignition riming a couple of degrees. It's possible you're hearing detonation noises, not bearings. Loosen the clamp screw that holds the distributor to the block, and turn it very slightly clockwise.
sepp #1071097 12/02/2014 12:02 AM
V
V Offline
Try retarding the timing as Jerry and others have suggested.
Once I had a 302 Ford knocking like crazy, I just knew it was about to throw a rod through the block. Ended up the timing was so advanced the detonation was causing the rod knock. Retarded the timing to spec and that engine ran like a sewing machine.
Good luck
Dave
sepp #1071121 12/02/2014 1:48 AM
Your description of a rattling noise is likely all of the valve train components rattling. All of the bearings don't go bad all at once. HRL has likely nailed your problem. I had a similar problem with a 235 and couldn't get rid of all of it by retarding the timing. Turned out that the part of the points which contact the lobes was worn down to near nothing. New points solved the problem. I need glasses and I am too cheap for my own good, not to change out those old used points earlier.
Carl
