Brrrr
place holder
2 members (Peggy M, MTD91), 141 guests, and 0 robots.
Topics128,274
Posts1,058,432
Members48,489
#1070818 11/30/2014 11:51 AM
I'm putting the Blue Funk's (see my signature) horn back together and am attempting to understand its workings.
When the horn button is depressed, it causes a plate to push a spring loaded contact point against the steering column, completing the circuit... right?
Is this diagram correct?
http://s837.photobucket.com/user/da...&_suid=14173445676680346773220805444
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
Davey Do #1070829 11/30/2014 2:49 PM
I have more zippers then a pair of cargo pants
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
Davey Do #1071004 12/01/2014 7:51 AM
Thanks for the diagram, Joe.
I added to the previous illustration with a question, incorporating an excerpt from your diagram: Specifically, is the circuit completed at the point where the end of the spring meets the edge of the steering wheel mast?
http://s837.photobucket.com/user/da...amp;_suid=141741642445708749389373850446
Dave
Davey Do #1071017 12/01/2014 10:59 AM
Yes Davey, the wire is hot all the way from the ammeter thru the
horn and right up to the ring on the mast jacket bearing and thru
the spring loaded sliding contact. You are simply shorting it out
at the steering column thus completing the circuit.
dg
Denny G
Sandwich, IL
Davey Do #1071023 12/01/2014 12:16 PM
Amen! Thanks, Denny!
Dave
