| | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I'm putting the Blue Funk's (see my signature) horn back together and am attempting to understand its workings. When the horn button is depressed, it causes a plate to push a spring loaded contact point against the steering column, completing the circuit... right? Is this diagram correct? http://s837.photobucket.com/user/da...&_suid=14173445676680346773220805444
| | | | | Joined: Aug 2014 Posts: 213 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 213 |
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Thanks for the diagram, Joe. I added to the previous illustration with a question, incorporating an excerpt from your diagram: Specifically, is the circuit completed at the point where the end of the spring meets the edge of the steering wheel mast? http://s837.photobucket.com/user/da...amp;_suid=141741642445708749389373850446 | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Davey, the wire is hot all the way from the ammeter thru the horn and right up to the ring on the mast jacket bearing and thru the spring loaded sliding contact. You are simply shorting it out at the steering column thus completing the circuit. dg
Denny G Sandwich, IL
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | | | |
