| | | Forums66 Topics128,010 Posts1,055,298 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I have a 53 chevy truck with a 12 v system and a ballast resitor . My question is I notice with the points closed I don't get a light on with my light tester at the wire at the distributer that goes to the negative side of the coil . I do get a light on my tester when the points are open at the same spot . Does anyone know why ?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | because when the points are closed you've applied a ground, and when they're open your meter is completing the circuit - all good
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Electricity takes the path of least resistance. dg
Denny G Sandwich, IL
