7 members (tclederman, Hotrod Lincoln, klhansen, UtahYork, Leo, Goach2, 1 invisible),
137
Mod | | | Forums66 Topics128,185 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | I thought I had all the bolts in the fender bit kit, but it looks like the inner fenders are mounted to the toeboards with carriage bolts due t the square holes in the toeboards? Can anyone confirm this and also suggest correct size? Thank you | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | On my 52 GMC there were rectangular holes in the inner fenders not the the toe board of the cab. These holes on the inner fenders are for rectangular captured nuts. There are 5/16 x 18 cap screws about 3/4 to 1 inch long that secure the inner fenders to the toe board screwed in from the cab side. Several of mine were missing too so I made replacements and welded them to the inner fenders. | | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | Left side inner fenders have round holes, and there are captive nuts on the parking brake bracket for the 5/16 hex bolts. The right side inner fenders have captive nuts as mentioned by Huck above, which take a special low profile headed 5/16 bolt, in order to not make a bulge in the floor mat. I have never seen this special bolt personally. I am not that picky about a fastener which no one will ever see, and a standard hex head doesn't seem to make a bulge in my floor mat even with a flat washer on it.. Carl
