1 members (Hanks custodian),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 9 | Hello, I have two Harrison Heaters that came with my truck when I bought it. Is there a registry or anything that can tell me which one is the correct one that would have been in the truck from the factory?
Thanks, Bobby | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Bobby, Here are some photos of the heater for the 1946 Chevy. You will need two ducts under the dash (they fit in the slits at the top of the dash) for the windshield defroster to work. Be aware that many types of heaters were used in these trucks-whatever could be found, but the heater below was the only one listed in the Salesman's Handbook. Harold 1946 Heater
Harold Is a restoration ever finished? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no 'registry' about anything on these old trucks, but you can find various manuals here, there may be something in the Master Parts Manual .... but heaters were dealer installed accessories, not factory options, so your truck didn't come with one from the factory Bill | | | | | Joined: Jan 2014 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 9 | Thanks Harold and Bill!
Harold, Good news is that one of the heaters looks like the one in your picture. The bad news is that it is missing the defroster blower portion off the top.
Thanks, Bobby | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Bobby, Place a notice in the Parts Wanted section. You may get lucky. Be sure & ask for a photo to verify you get the right one. You may even post a photo of what you want. Also check Ebay from time time. They do pop up. Good luck, Harold I have added 3 more photos of the heater. Heater
