5 members (Jeff Ogden, Otto Skorzeny, KingG, Hotrod Lincoln, 1 invisible), 29 guests, and 5 robots.
Topics128,012
Posts1,055,316
Members48,419
#107079 04/26/2004 3:07 AM
Junior Member
Junior Member
I am currently replacing the bed on my 53. I plan on using “benelex” for my bed blocks. It is a laminate of wood particle sheets bonded by synthetic resin under pressure. It is a very dense, heavy, and solid material. It was manufactured by Masonite in the recent past, but is no longer in production.
It has the following specs:
Compressive strength of 24,000 psi minimum perpendicular to sheet.
Tensile strength of 7,000 psi minimum parallel to sheet and 450 psi minimum perpendicular to sheet.
I have had heavy equipment sitting on it for 20 years, have submerged it in water for weeks, and have baked it in the hot Florida sun, with no change in appearance or dimensional stability. Due to lack of a “real” winter in Florida, I even froze it in the freezer..
If anyone knows why this is not an acceptable material, please let me know.
I have over 50 feet of 2 x 2 inch blocks. If anyone needs 2 x 2 X 2 1/4 or 2 x 2 x 2 1/2 blocks, I offer a set for *free* to any stovebolter, while it lasts. Let me know if you need some.
53 Chevy 3100 ( 5 window )
53 Chevy 3100 ( 3 window )
#107080 04/26/2004 3:41 PM
I would be happy to pay shipping.
Is 2" square big enough?
#107081 04/26/2004 7:56 PM
Junior Member
Junior Member
Well ttt8, I don't know what the original size was. When I took my bed apart, the PO had used pipe fittings to hold the bed up..... Old post had several opinions on what would work.
52PU said in a post last May: “My Chevy Duty Replacement blocks are. 1+13/16" high x 2" wide x 2+1/4" Length. The length part rests on the top of the frame, then drill hole down the center of the top. The overall height with thin rubber cushions on either side of the block is 2+1/16". You would not want the blocks any shorter than 1+3/4" high because you will have problems getting on the running board splash aprons.”
Fatboy said: “the block is made from hardwood. [most likely oak ] and it is 2 5/16 " square. The grain runs up and down and the hole is centered.”
If you want to try these 2 x 2 blocks, email me at [email protected] and I'll send you some.
Joe
