| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Purchased and mounted on my restored wheels. I had the wheels blasted and I did do a couple of rounds priming and blocking on each face that goes out. I think it was worth the effort. They are Pacifica tires and I was able to purchase them for $190 each. That included tubes and flaps. I was surprised at how easy mounting the tires were. On another note if you plan to do this yourself... Take the tires to a tire shop and have them break the beads on their tire machine. Once the beads are broken down you can manage the rest pretty easy. http://s1006.photobucket.com/user/r...hevy%202%20ton%20Truck?sort=3&page=1 | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Hey Randy --- By any chance have you found a source for replacement lug bolts? Checked my local NAPA and they don't have anything that far back. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I did just replace all of them. It had 9/16 on one side and 5/8 on the other side. I was not able to find any with the correct knurl diameter in 9/16" so I went with 5/8" on both side, but kept the 9/16" up front. I was just looking at the specs from 1946 and it list 5/8 from the factory, but the 5/8 were certainly newer than the 9/16 on my truck.... Who knows what life these old trucks had on the farm before we acquire them!
I will post up the Dorman numbers tomorrow for you. | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | I've noticed on several of these BB wheel posts there's 9/16 and 5/8 stud sizes. I figured the 9/16 were for 1.5 Ton and the 5/8 were for 2 tons. I got all new 5/8 lug nuts from the truck shop that made my new U bolts for the springs. I've never had to replace any lug bolts. Amazing for almost 70 years old! | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Since the lug nuts on the 2 ton are flat not conical you could use any industrial tall nut.
More important - if you have 9/16 up front, what effect is that going to have on the rotor selection for your disk brakes kits if we have 5/8's? | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Jim, None of that changes. You bolt the rotor to the back of the hub. leaving the hub face untouched.
I used a Dorman number 610-071 for my stud and a 611-057 for the nut. Amazing how the price adds up. I was over $200 in hardware on the rear hubs... Small price to pay I guess. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I have noticed a few threads now where napa wasn't of any help for studs. I just took one down to my local store (lucky for me it's a warehouse) and they mic-ed em and handed me 20 ready to go... Even had an inch longer as I asked for. Matching them up is much more productive than the alternative. IF you go by the 'book' then 50's 5/8's studs are the same.
What I have found in my run with these trucks is 9/16 went on 1.5 and 2 ton trucks 42' and earlier, and 46- received the 5/8 larger studs. Unconfirmed, but so far true of my herd and parts hunting. | | |
