13 members (Otto Skorzeny, Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 4 | I just bought a real nice '52 Five Window street rod pickup truck and want to install a Third Brake Light inside the cab at the rear window position.
Can someone suggest a vendor, or decent light assembly for interior installation mentioned above? Any ideas and/or personal mod's would be appreciated as well. | | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | I purchased two of these from J & L enterprise. Their website is jandlenterprise.com. I installed one in my Camaro and will install the other in my 55.1 cab. Installation is straightforward and it works well in my 2nd gen Camaro. They were very good to deal with. I see you are in NJ. They are in CT so are fairly close. There are other options but I met them at the car show up in Rhinebeck NY and am happy with my purchase. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Those are very nice units, the best I've see on the market yet. That along with a pair of LED standard taillights would really go a long way in lighting up the rear end of a stovebolt. I believe one of the 'bolters here posted the installation of one in his truck a while back. I think it might have been Gus??? Is your 55.1 a 6v system Kery? I noticed in their 6v installation instructions that it's only shown for a Positive ground. That seems sort of odd to me because most 6v systems other than the GMC's were Negative ground. Shouldn't be any problem, just reversing the yellow/green with the black/white would reverse it. Don't know why that isn't noted in their instructions. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Here's what I used,a 3rd light 'pirated' from a Nissan Micra,there are many others suitable for this too. I masked off the glass and used glass primer (used in bonding glass to bodywork.) I then attached it using 3M double sided tape. Fixing it to the glass avoided any metal surgery and being L.E.D. should last a while too,if in the event it fails i'll just get another. Cheap,effective,nice and bright and gets the job done.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | Denny My 55.1 was converted to 12 V before I got it. All the electrical devices that are now working are now 12 V. | | | | | Joined: Jan 2010 Posts: 4 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 4 | Kary, just the item I've been looking for. Many thanks for your help! HAPPY HOLIDAYS to ALL! TED....... | | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | Hope you had a good holiday and I hope the light works out for you. | | |
