| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Anyone know anything about these $15.95 plugs? Pulstar Plugs
~Jim
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | P.T Barnum is alive and well, and selling spark plugs!  Jerry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | P.T Barnum is alive and well, and selling spark plugs!  Jerry My thoughts exactly, Jerry.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I only paid like $8.00 apiece for the ones in my new car, "LASER IRIDIUM", the old set ran 100,000 miles and showed little deterioration. Unless you aren't getting spark to the cylinder at all. A spark plug won't give you any more power. You don't need a 50,000 megaton ignition under most situations. All you need is "ignition" hence the term "IGNITION" System. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I have no personal need for these plugs. I rarely ever drive more than 1,500 miles a year. Curiosity is all that drives my question.
~Jim
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A local trade newspaper had a big front page article about them. They interviewed the head of the co. They showed dyno tests the should a significant increase in torque & hp. I just put new plugs in my HHR & the rest of my vehicles I don't hardly put on any miles. So I'm not going to try them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A local trade newspaper had a big front page article about them. They interviewed the head of the co. They showed dyno tests the should a significant increase in torque & hp. I just put new plugs in my HHR & the rest of my vehicles I don't hardly put on any miles. So I'm not going to try them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | I have made hundreds of dyno runs over the past 30-something years. It's fairly simple to fudge the numbers to show a power increase if the dyno operator has a product to sell. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Run a dyno test on an engine with old plugs (and probably poorly tuned as a consequence).
Change the plugs with any plugs. Tune the engine.
Run a dyno test.
What results do you expect?
Look at the controlled test at the links posted above.
Those plugs provided only a modest increase in power and mpg. The payback might have been OK (not substantial, but OK) if you drive your vehicle a lot.
| | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | With the antiquated points ignition and, carburetor fuel delivery systems (both of which begin their gradual degradation until their ultimate failure due to normal wear and tear upon the first revolution of the crankshaft), these plugs will foul just as quickly as the original equipment plugs did. With the advent of computer controlled electronic ignition and fuel injection, modern engines are not subjected to the problems associated with the old system, and therefore you can run plugs for pretty much the life of the engine. I have put 173,000 and 161,000 miles on two Dodge pickups on the original plugs. The 173,000 mile one developed a sloppy overhead cam chain and was sold at auction (still running, just a bit noisy when engine was cold) and the 161,000 mile one is still in service and runs like new. Carl
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My F-250 had 215,000 miles on it when I replaced the plugs. Even then there was no noticeable engine problems.
~Jim
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | With the antiquated points ignition and, carburetor fuel delivery systems (both of which begin their gradual degradation until their ultimate failure due to normal wear and tear upon the first revolution of the crankshaft), these plugs will foul just as quickly as the original equipment plugs did. With the advent of computer controlled electronic ignition and fuel injection, modern engines are not subjected to the problems associated with the old system, and therefore you can run plugs for pretty much the life of the engine. Like Carl, states, I can't see any real advantage to them. If they are being used with a coil on plug application or even an HEI setup, maybe some modest gains. Nothing to warrant the price tag on them. I'm willing to bet just going a couple points hotter, using an "S" type plug, or even indexing your spark plugs would probably have about as much of an effect as a $15 magic plug. Buy some R45S plugs for $2.00 each and be done with it. | | |
