Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (MickeyP, Gdads51, Otto Skorzeny, Bill Hanlon), 48 guests, and 0 robots.
Topics128,007
Posts1,055,279
Members48,418
#1070364 11/26/2014 11:55 PM
My 1950 3800 has the foot-stomp starter and I'm converting to 12 volt. My original ignition switch has 2 positions, but three posts on the back. One for Batt, another for ignition (running), but whats the third post for?
When I got the truck there was no radio, no heater fan switch, and nothing connected to that third post on the ignition switch. Is that where accessories like the radio and fan are powered?
Thanks - Bruce
Ok, reading through some posts from 2012, it looks like that third post is for the accessories. I'll hook her up and see how hot that post is.
Bruce
If you use that third post for accessories, make sure you don't use the accessories without the engine running. With the key on and the engine isn't running, the coil is energized and you will eventually 'let the smoke out' of your coil, as they say.
Carl
Hmmmm.... Is there a way to avoid this fate Carl?
Bruce
On my 2 position switch the terminal that points down is for power and the two upper terminals are both switched at the same time so accessories should not be powered with switch off. Use a voltmeter or test light to verify.
Ed
The only way to run Accessories with the stock switch is to hook them to the Battery post. And use a switch in line to turn them on and off. But, beware, they can run down the battery when you use them. Do not leave the key "On" with the truck not running. The coil, or the points will suffer.
Steve H
