3 members (Bill Hanlon, 32Fordpuchoptop, 1 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,635
#1069918 11/24/2014 5:05 AM
Hi y'all
I have all original 1954 3600 farm truck.
My question is once the engine is running do you need battery power for anything or can the generator handle the electrical load of running the engine and a couple of gauges?
If your generator is working correctly, your engine will run with a dead battery once started.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
The generator will supply the electrical needs of the engine, but a battery should still be in the circuit to act as a "shock absorber" for voltage spikes. I've seen some systems develop voltage spikes of over 100 volts when a battery is disconnected with the engine running. While this isn't particularly harmful to an older system, anything with solid-state components like a radio or other modern electronics can be damaged in an instant.
NEVER, EVER DISCONNECT A BATTERY CABLE WITH THE ENGINE RUNNING TO "TEST" AN ALTERNATOR! Generators, not too bad.
