0 members (), 125 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Guys,
My head liner and door panels are beginning to sag.
I've heard that thy were "cardboard" Can they be saved by removing them, bonding something (vinyl?) to back side and reinstalling, or are there readily available replacements? So far I haven't seen any.
Bill,
Almost all the reproduction parts vendors sell those panels. Check the Links section of Stovebolt.com
The reproduction panels are also cardboard. You could try to seal the back/sides of the panels with epoxy or urethane paint/primer/sealer.
The reproduction headliners are prone to shrinkage in my experience. My next headliner replacement will be homemade, using the old reproduction one as a template with extra material in the areas where the gaps are currently.
Carl
52 Carl,
What material do you plan to use?
Yes, they are mostly cardboard but, they are all not awful.
Look for "bowtie bits" on ebay and they have a really good set for about $30 which is what I used. I ruined two others from the usual vendors and then found this one.
I think the trick is to pre-shape the headliner and install it as one piece. Mine popped in a couple of minutes and is better than I ever thought could have been achieved from with lowly cardboard.
https://www.stovebolt.com/ubbthread...in=107770&Number=1050490#Post1050490
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
Moderated by  ndkid275, Phak1
