2 members (DES57, 1 invisible),
142
Mod | | | Forums66 Topics128,153 Posts1,056,827 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Swap the pulleys and you'll be fine. The offset pulley has to be on to align the belt. | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | The small diameter pulley is going to be needed to make the alternator start charging on startup. It spins the rotor faster and gets the charging started sooner. With the bigger pulley you will need to goose the throttle after starting to get the amps flowing. Search "2-groove alternator pulley" on Ebay. There are at least 20 of them listed today. Install the 2 groove small diameter pulley and use the front groove, and things will line up right. I use an impact wrench and a 15/16" socket to install/remove those pulleys. Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | The small diameter pulley is going to be needed to make the alternator start charging on startup. It spins the rotor faster and gets the charging started sooner. With the bigger pulley you will need to goose the throttle after starting to get the amps flowing. Search "2-groove alternator pulley" on Ebay. There are at least 20 of them listed today. Install the 2 groove small diameter pulley and use the front groove, and things will line up right. Thanks for the tip. Will I need to change V-belts? I use an impact wrench and a 15/16" socket to install/remove those pulleys. Jerry My son suggested doing that but the shaft will spin with the nut, won't it? That seems like it wouldn't work. I spent 2 hours today searching local hardware stores for a 15/16" offset box wrench. Couldn't find one. | | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | If you use the impact gun the shaft should not spin after the nut is loose,also make shire the belts do not bottom out in the groves of the pulley,if they do it means that the belt is worn out,look at the groves in the pulley and make sure that the sides have not worn out also. Belts have two widths, one is an "a" width and one is a " b" width. Pat
1966 Chevy C 30 1 ton truck
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If you wire it as a three wore alternator you don't have to worry about ordering a different pulley. It will start charging on start up. Most of the time with the one wire though at start up the engine is usually revved up enough to start it charging before idling back down.
It's really not enough of an issue to hunt a different pulley when you have one that will be fine. Putting it in reverse or lwo to take off will give enough rev to make it turn on.
But Hotrod is right, using a smaller double v-belt pulley will turn the shaft faster making it turn on usually without revving the engine.
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | The rotor has enough inertia for the impact to spin the nut on and off without a problem. Conservatively, I'll bet I've done several hundred that way, maybe a thousand or more. Jerry
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | Like Jerry says, use an impact it will work just fine. I've done it many many times myself, without a problem.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Unless you can counterbore the smaller pulley from the front, you'll run out of thread area on the shaft after shimming it out. No way to reinstall the nut and lockwasher. Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Unless you can counterbore the smaller pulley from the front, you'll run out of thread area on the shaft after shimming it out. No way to reinstall the nut and lockwasher. Jerry Yes sir. You are very correct. I missed that detail. I think what I've got will probably do just fine. If not, then I might just fabricate a new bracket.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I bet it will be fine. A lot of times after a few starts the one wire will start working right away. If not just goose the gas a little or if standard shift put it gear and as you rev the engine just a tad to take off it will go to work.
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | You can try inverting the alternator and see how it lines up. Mount the alternator's factory top bolt holes on the outside of your existing mount. You'd still need an offset mount, but it wasn't difficult to make one. Photos of what I'm trying to describe. You'd also want to flip the back plate so the 1-wire connection is away from the engine. Brad Wrench Fetcher, PhD | | | | | Joined: Jun 2012 Posts: 1,748 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,748 | Just keep the wires away from the manifold. Now you know why ClaudeTheTruck, rotated the back cover. I pulled the wires over to the inner fender straight from the back of the Alternator. A clamp and all was good.
Steve H
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | You'd also want to flip the back plate so the 1-wire connection is away from the engine.
Brad Brad, These 2 videos on YouTube helped me understand what I will see inside an alternator. I was reluctant to take mine apart for fear of the unknown parts inside. Now I see that removing and rotating the back cover is nothing to fear. Thanks for the tip! Alternator Video 1 Alternator Video 2 | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | All you need is a straightened-out paperclip to hold the brushes back while you clock the rear housing to the position you want. Just be sure to keep the stator and the rear housing together. Jerry
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | All you need is a straightened-out paperclip to hold the brushes back while you clock the rear housing to the position you want. Just be sure to keep the stator and the rear housing together. Jerry And where exactly would I put the paper clip? Update! Never mind. I just opened up the case and the brushes popped loose. I got it all back together just fine. On another note, after watching those videos I see where he says you can excite a self exciting alternator by briefly supplying 12 volts to the #1 terminal. That could be done with a simple push button located on the dash or hidden somewhere. Of course it might not be needed at all. Just another way to get the alternator excited without revving the engine.
