5 members (NJC, Gdads51, ronsway, Hush, 1 invisible),
143
0
Mod | | | Forums66 Topics128,101 Posts1,056,179 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | I have a 1948 Chevy 3100 truck. It has a spotlight on the driver's side post which needs a bulb replacement. I am not having much luck finding one. All I find is the entire spotlight unit. Any idea as to where I might locate one? | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Unityusa.com should have it. Others suppliers may be out there.
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Does your light use a sealed beam bulb? If so Unity may be able to help. If your light has the reflector bulb combo you'll likely need to buy an 1183 bulb for a six volt application. I don't know what the bulb would be for 12v if you've converted to 12v. If you're still 6v and can't find 1183 bulbs locally you can get them on ebay.
| | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | It looks like a sealed beam light bulb and it is loose in the housing. I would think there is a spring or something behind the bulb to push it up against the housing if that makes sense? | | |
