4 members (Otto Skorzeny, Steelonsteel, Woodcmiami, Millenimech), 84 guests, and 2 robots.
Topics128,050
Posts1,055,760
Just curious if anyone has any input regarding these for both front and back. Still looking for best way to lower the truck without having to go bags or hydraulics. Thanks
Lowering blocks wont work in the front. You can use 2,3, or 4" blocks in the rear,,also remove a couple leaf springs.
A drop axle from Sids is the way to go in front www.droppedaxles.com
Blocks on the front would be illegal, even then, they would only lower it if the spring was under the axle. You don't mention what year/model truck you have, on 3/4 and 1 tons, and 1/2 tons after '55 2nd, lowering blocks will not work on the rear, either.
Like Marty stated, Sids would be the way to go on the front.
Bill Burmeister
