| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 |
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Where did you purchase this material? Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2012 Posts: 1,748 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,748 | I used the same stuff. Harbor Freight.
Steve H
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | I picked it up at Menards. Harbor freight carries similar stuff. It's a little over a 1/4" thick and cuts and lays out nicely. I used 3M Vinyl top spray adhesive. The heavy duty stuff in an orange can. Spay the surface you are going to apply it too and the backside of the mat. Touch them together and they don't move so take care getting it positioned.
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Any idea yet how it's performing? How much difference in the sound?
1951 3100
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | The trucks not on the road yet. Rapping on the sheet metal before and after there is a difference. I figure I can always double up the layers if needed.
| | | | | Joined: Dec 2013 Posts: 178 Shop Shark | | Shop Shark Joined: Dec 2013 Posts: 178 | I like the pics. Your gauges looked good too! My 47' speedo needle is faded semi transparent red. Do you know what color is correct?
Have you ever noticed that anyone driving slower than you is an idiot and anyone driving faster than you is a maniac? - George Carlin
| | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | As far as I know your speedometer needle would be white, same as my 49'
| | | | | Joined: Aug 2009 Posts: 197 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 197 | Hey BTZGUY, this is Archie Bentz, I use to own Archie's Sandwiches 'n Spirits 91-95, before I sold to Jan of the 'Breakers'. I still have my '46 Chev and was looking at your post, but since I can not glue this down, (still need access through floor for master cylinder and battery) would you recommend this laying loose under the floor mat? Would I know you by name? | | |
