| | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 23 | Po had removed the cab to redo the frame etc. but for some reason the steering is not or seems like it sits to far down for anybody but gumby.
From the bottom of the dash the space is 12" roughly and the shaft comes straight out,I have seen pictures where it looks like there is an outer sleeve then the shaft in the center.
The only way to put this one up as it is to actualy bend it. As it is it turns the wheels.
The steering box is mounted but it appears to have a shaft all the way through,I guess the question is does the box rotate within its mount? Or is it just the incorrect box?
<a href="http://s235.photobucket.com/user/mgb1234/media/Mobile%20Uploads/image-18.jpg.html" target="_blank">
<a href="http://s235.photobucket.com/user/mgb1234/media/Mobile%20Uploads/image-17.jpg.html" target="_blank"><img src="http://i235.photobucket.com/albums/ee73/mgb1234/Mobile%20Uploads/image-17.jpg" border="0" alt=" photo image-17.jpg"/></a> | | | | | Joined: Sep 2010 Posts: 1,700 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,700 | There should be a bracket like this. You need to loosen the steering box at the frame and rotate it up to the proper position. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Nov 2014 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 23 | Got it today ,two bolts going down through the frame with a cap that looks like a main bearing cap,loosened them up and rotated the column up.I was thrown off by later model steering boxes that the bolts actually screw into the box itself verses the clamp method.
Still missing the outer shaft tube and the dash mount.
I see different sizes of the dash mount offered 3" and 4" does it really matter which one?
I also pulled the top of the transmission off and had some stuck gears from non use,freed them up and now have all gears and a strong clutch to boot.
I also pulled and resoldered a leak in the radiator,cleaned,painted and reinstalled so that part is done.
All and all productive day and it reminds me why I like Chevy so much.
Thanks for the help.Your 38 is looking sharp. | | |
