| | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 32 | Have a c10 that is many different year pcs. on it. Im in the middle of restoring it and bought aftermarket heater knobs. They will wont stay on. They slide right off. Is there supposed to be clips inside to hold them in place? and if so, where in the world would I find them? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I did not ask this question when I did mine, and so the glue used may have been non-traditional. The knobs have been on and utilized for 3 years. No problems. So only you and I know that I potentially used a method that was not factory original. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | Perhaps you could also use some type of caulking which would set up enough to hold the knobs on but not enough to prevent them from being removed if necessary.
1965 Chevy C20 Stepside
