Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (68ironhead, Jon G, 3B, baldeagle, Jay R, walter74, carbking, Bill Hanlon, 1 invisible), 50 guests, and 2 robots.
Topics128,004
Posts1,055,247
Members48,418
#1069206 11/20/2014 1:23 AM
well I am sure it has been well covered but I'm too lazy to search. I have been driving my old 61 half ton GMC a fair amount though not daily. and it is a fairly worn 305 V-6 4 speed. a friend has a cousin with a rebuilt straight 6 out of about a 61 or 62 2 ton grain truck. seems like he said around 265 cu. inch. anyway if at some point I can get it without too much cash flow- I'm wondering if there is anything major I should look for in swapping. I assume the old 4 speed will be fine but probably bell housing and clutch will be different? likely have to change driveshaft length as well.I don't even know if it includes manifolds and carb or not but just wondering about what major things to check for. I currently have my radiator in the shop and they tell me it is beyond repair. they offered to put in a new 2 row core for cheap. I expect since I'm not pulling it hard it likely will keep the old engine cool enough but I may need to find a fan shroud to pull more air through it.
Skelflyer #1069218 11/20/2014 2:11 AM
A 1961-62 2 ton straight 6 would most likely be a 261.
My Blog
Skelflyer #1069243 11/20/2014 3:10 AM
You might be better off looking for a GMC engine as there would be less to modify? I think the 351 V6 is a direct drop in to replace the 305...
If you're ok with doing some modifications, than why not drop a small block Chevy in, they are cheap and everywhere???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Skelflyer #1069259 11/20/2014 3:43 AM
I bet 261 is right- and it's bored .010 over with new pistons and .010 under crank. I know V-8's are popular but I'm kinda partial to 6's whether V or straight.probably will just keep wearing out the old 305 but if the engine ends up being the right price and I can gather the necessary parts for the swap it is tempting- it's basically a new engine
Skelflyer #1069273 11/20/2014 5:33 AM
Pull out the V-6 and see what it would take to rebuild it.
