1 members (Shade Baby),
109
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | What cartridge and where can I get one that will fit in the AC L-4 oil filter canister? Thanks. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | It looks like a Wix51010 might fit. Same as a Ford Tractor. Check the measurements
Steve H
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Steve, Thanks, I will check it out. Harold
Harold Is a restoration ever finished? | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Harold, Don't know if you looked here or not. Lots of good info. Dan | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Steve, It looks like a Wix51010 might fit. Same as a Ford Tractor I looked at the WIX web site loaded the P/N WIX51010 and got this reply: There is no information available on the part number you submitted. I will take the canister into a parts house and check various filters. There must be one out there somewhere. Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tim, Thanks. I never thought about Ebay. Have you used this filter in the AC L-4 canister? Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Harold,
I do not have that canister filter.
Sorry,
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 |
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Brian, Thanks I will check with them. Harold
Harold Is a restoration ever finished? | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Still searching for a filter for the AC L-4 oil filter. The WIX 51010 fits in the container but is about 1/4" too tall. The lid cannot go all the way down to seal. Any other suggestions appreciated. Harold
Harold Is a restoration ever finished? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Harold, Have you checked out this tech tip? Pat was helpful in setting me up with the correct housing/bracket for my project. I would bet he knows some interchange options off of the top of his head. http://www.stovebolt.com/techtips/engines/oil%20filters/index.htmlPaul | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Paul, Yes, he helped me ID the filter housing. I have sent him 2 emails regarding the filter element, 1 in Nov & another in Dec but have not received a reply. He must be busy. Harold
Dec 5 Heard from Pat. He advised the original filter was a AC P-110 paper oil filter. I cannot find a cross reference for this number. Can anyone offer a solution? Thanks Harold
Harold Is a restoration ever finished? | | | | | Joined: Aug 2014 Posts: 8 New Guy | | New Guy Joined: Aug 2014 Posts: 8 | I have the same filter in my 47'. Just go to NAPA and tell them the filter number. They probaby have a direct replacement on the shelf. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Try the Wix WL7000 it might fit. Get the measurements, I would bet that NAPA has one that will fit.
Steve H
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Steve, I cannot find any info on the WIX WL7000. It does not show on the WIX site or any cross reference. Do you have a site or another #? The closest NAPA is 1 hour away. I tried to call but they were too busy to look it up in their records. Thanks, Harold
Harold Is a restoration ever finished? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Tim, Thanks for the links. The name has changed to KILLER FILTER. They must make it since the WIX site has no info on the WL7000. I'm surprised Google did not cross reference this when searching for WL7000. Thats what is good about the FORUM; there is always someone that can supply the correct info. Harold
