| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | I just ordered the muffler strap for my muffler I'm using the original round one on my 53 chevy truck does anyone know how u are suppose to install those are they cut to fit then spot welded ? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I usually spot weld the threaded end to the strap. The other end can go either way. On the 2 ton I used a dual in and out oval muffler. I just sheared a strap from the right gauge sheet metal, attached the threaded end and looped the other end through the slot in the bracket, leaving it several inches extra long. That way I could make an adjustment if necessary. When you tighten it up the muffler body holds the loose end against the bracket and secures it. | | | | | Joined: Jan 2009 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 246 | So on the other end not the threaded part do you spot weld it or can u use a rivet to secure the strap loop ? | | | | | Joined: Nov 2011 Posts: 1,609 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,609 | If the unsupported strap ends are sandwiched in between the muffler and the supporting side of the strap, it is trapped and needs no fasteners. Simple design, but it works great. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Paul states it well - simple design, but it works great.
I recently put one on for the first time in over 10 years. I scratched my head a little, thinking about it before I had the parts ready to install. But, the parts fit only one way and they nicely/neatly do the job (no welding/trimming if you have original size/style muffler).
