| | | Forums66 Topics128,208 Posts1,057,448 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 24 | Currenty running a 4 gauge. I read somewhere that a heavier cable may be required and help with slow starts? Any suggestions? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, 4 gauge is modern 12V weight, you need to go heavier, best if you use 0 or 00, welding cable works to make your own if no shops around you have good heavy cables .... also make sure all your connections are clean and tight
Bill | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | A lot of guys go with 0 or 00. I've read that the factory used 1 gauge. I have 0 on my '38. You should be able to find heavy cables at a farm store. Make sure your connections are clean.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I cannot remember where I read that 2 gauge was used with 6v.
Nonetheless, I use 00 (2/0) gauge. Tractor Supply Company sometimes has them.
For what it is worth, it looks lie the Master Parts Catalog gives the following "equivalents" from Packard:
hot cable: CL-39 ground strap: 5L-14
| | | | | Joined: Jan 2009 Posts: 24 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 24 | Thank you ALL! If it wasnt for people like you, I'd have a garage full of parts! Going cable shopping today. THX! | | |
