3 members (Hush, Peggy M, 1 invisible), 116 guests, and 2 robots.
Topics128,196
Posts1,057,395
Members48,471
Currenty running a 4 gauge. I read somewhere that a heavier cable may be required and help with slow starts? Any suggestions?
yes, 4 gauge is modern 12V weight, you need to go heavier, best if you use 0 or 00, welding cable works to make your own if no shops around you have good heavy cables .... also make sure all your connections are clean and tight
Ex Hall Monitor
Ex Hall Monitor
A lot of guys go with 0 or 00. I've read that the factory used 1 gauge. I have 0 on my '38. You should be able to find heavy cables at a farm store. Make sure your connections are clean.
I cannot remember where I read that 2 gauge was used with 6v.
Nonetheless, I use 00 (2/0) gauge. Tractor Supply Company sometimes has them.
For what it is worth, it looks lie the Master Parts Catalog gives the following "equivalents" from Packard:
hot cable: CL-39
ground strap: 5L-14
Thank you ALL! If it wasnt for people like you, I'd have a garage full of parts! Going cable shopping today. THX!
