0 members (),
171
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | does anyone know if there is a kit to install disc brakes 6 lugs on a stock 39 spindle? any info is appreciated. | | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | Anyone? 39 jc 1/2 ton I want 6 lug disc brake conversion. Help. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | You might give this some consideration. I replaced the front end on my '40 with a '51 assembly. It is a direct swap. That lets you use the '47 up disc conversions.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | Thank you very much. That's what I needed. | | |
