3 members (51sub, Jon G, 1 invisible),
110
Mod | | | Forums66 Topics128,288 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | The Blue Funk (see my signature) had been a little difficult to start now and again since it's been back on the road last May.
There was nothing was really consistent (that I could tell) about the trouble starting, whether cold or warmed-up. The engine always started- it was just a combination of choking, pumping the pedal, pedal to the floor, encouragement, pleading, whatever. Once it started, the engine ran fine.
I stopped by the Gas station, and due to repairs (I guess) premium was the only gas available. I thought, what the heck? a few gallons won't hurt it.
What a change! The engine fires up first time, every time and runs like a champ!
Tell me what you think.
Thanks! | | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | High octane gas shouldn't be necessary with the compression ratio your engine has. It might be coincidence, but if it helps, the only downside to running high test gas occasionally will be a few more bucks out of pocket when you gas up. Jerry
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Thanks, Jerry! the only downside to running high test gas occasionally will be a few more bucks out of pocket when you gas up. Are there any other downsides to regularly running high octane gas than the money?
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I found running a better grade of gas gave me a slight boost in fuel mileage. Maybe not enough to justify the cost difference, but it did run a bit better. Don't know of any downside. | | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | There might be a slight increase in exhaust manifold temperature, as premium gas burns slower than regular and some of it might still be burning as it leaves the cylinder. You can advance the timing a few degrees if you run premium all the time and get the burning process started a little sooner. Just be careful not to advance it so far that the engine pings when running regular gas. Jerry
| | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | I have always run regular gas (87/89) octane but.....one day I was at friends and did a quick carb adjustment on his car and he threw a bit of aviation gas in my truck ..54 with a 235. Now that woke it up.at that time it was runnig oem points and condenser it started quick and pulled nice.ran the av gas that one time only. The only time since that my truck started that nice was when I put a hei dist.in....edit...av gas was mixed in with a half tank of reg gas not straight av gas.that would not be good
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | | | | | | Joined: Nov 2002 Posts: 2,786 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,786 | Before ethanol:
A gallon of 87 octane regular contained 117,600 Btu/gallon A gallon of 89 octane contained 117,600 Btu/gallon A gallon of 91 octane contained 117,600 Btu/gallon A gallon of 93 octane contained 117,600 Btu/gallon A gallon of 100 octane avgas contained 117,600 Btu/gallon
Ethanol (according to the scientists, not the government) contains 67,000 Btu/gallon.
Ethanol is often used as an octane booster as the AKI octane of ethanol is 116.5.
Mixing gasoline and ethanol will ALWAYS result in less Btu/gallon than any grade of unadulterated gasoline.
As Jerry mentioned, the higher the octane, the SLOWER the fuel burns. Often, higher octane fuels will NOT completely burn in a low-compression engine, resulting in both a loss of power and fuel economy. This is certainly true of avgas.
If one does find the higher octane fuel (or avgas) is working better than one's current fuel in these lower compression engines, then one should try the same octane fuel as before FROM A DIFFERENT STATION! Possibly the current station's tank has some contaminents or???
Now if one has a 13.5~15:1 compression race engine, then the avgas should work well.
My shop truck (not a stovebolt) runs 10.28:1 (measured when we built the engine, NOT advertised) compression. Under normal conditions, I run 87 octane fuel with NO issues. When I pull the 16 foot trailer, I put 89 octane fuel in the tank.
Seriously guys (and gals), the lower compression engines should run WORSE on the higher octane fuel PLUS it is more costly.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Practical experience leads me to say other wise. The old 261 would run a bit smoother and do a little better on fuel mileage using the higher grade fuel.
I'm not a scientist so can't explain the why, and perhaps my results aren't typical.
But I also know the old engine would run better on gasoline before the ethanol was added. | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Seriously guys (and gals), the lower compression engines should run WORSE on the higher octane fuel Huh! Go figure! Thanks for the info, Jon. Could it be, that since the Blue Funk ran well on regular fuel and the difficulty starting was the only issue, the higher octane fuel is merely a shot in the arm; a kind of boost, to get it going? | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Could it be, that since the Blue Funk ran well on regular fuel and the difficulty starting was the only issue, the higher octane fuel is merely a shot in the arm; a kind of boost, to get it going? You can advance the timing a few degrees if you run premium all the time and get the burning process started a little sooner. Okay- What IF the timing had already been too far advanced- would THAT have caused the difficulty starting and the subsequent easy starting on Premium gasoline? The difference is just phenomenal! I mean, the Blue Funk starts first time every time! | | | | | Joined: Nov 2002 Posts: 2,786 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,786 | How old was the fuel with which you were having difficulty starting?
Modern fuel goes bad within 3~6 weeks. Hard starting and sluggish until engine is hot, and then will run OK.
Perhaps your issue was simply old fuel.
With my collector vehicles that are started infrequently, I don't even attempt to start on the fuel in the tank. Start with starting fluid and save the battery and starter.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | With my collector vehicles that are started infrequently, I don't even attempt to start on the fuel in the tank. Start with starting fluid and save the battery and starter.
Jon. I also use starting fluid if the vehicle has sat longer than 2 weeks, works great.  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | After my '50 has sat for some time, a month or even over the winter, I just pull the choke out, pump the peddle a couple of times, when I get fuel up to the carb and it starts right up. In the 10 years that I've had her I've never had a problem with it starting, even after setting for a long spell. You guys must be getting some real bum petrol where you're from. Haven't had trouble with the generators, blowers, chainsaws, mowers or any of the motors that have sat with fuel in them over the winter or even in some cases for years. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Like they say everyone has an opinion, like ahh, well you know what I mean  I avoid starting fluid (ether) like the plague. It's always the last choice I have when all else fails. I know it's an old mechanics tale that engines get addicted to that stuff but I've seen diesels that wouldn't start without it once it was used regularly on them. Even in 90 degree weather. | | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | I'm sure the fuel was fresh: I ran out of gas not too long back and a Good Samaritan got me home. I put a few gallons of gas (also fresh)I keep for my lawn mowers in the Blue Funk and drove it into Town for more gas. It wasn't long after that the Premium gas was added.
As I said, the change has been phenomenal: starts easily and runs great!
I've heard that if starting fluid is needed, regularly, the engine is in need of other things, like a Tune Up. Initially, last Spring, when I was atempting to get the engine going after sitting for nearly three years, I did a couple of squirts of starting fluid, but no more.
Anyway, thanks for the discussion, Guys! | | |
