3 members (klhansen, UtahYork, 1 invisible),
114
Mod | | | Forums66 Topics128,090 Posts1,056,374 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | I am looking for a harmonic balancer pulley for my 235 in my '58 Apache. The current one does not have a smooth pulley groove; looks like it has been plagued with rust and I think it is the root cause for premature wearing of the fan belt. Looked online with NAPA, AUTOZONE, Rock Auto and Advance Auto, no luck. I would appreciate if anyone knows where one is located and the best way to change it out without removing motor from the truck. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would recommend pulling the belt, start the engine and smoothing the pulley with sand paper. You can run it for a minute with out overheating it. Pitting does not seem to affect a belt, but raised rust it tough on them. Ebay is always a good place to start if you need to replace it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I do not know if your still looking but there is a guy on Facebook that has this If you have FB you might want to look him up Just FYI. I do not know him but he belongs to a group called Stovebolter's R'Us.
Andrew Pizano
November 12 at 8:29pm · Edited .
Chevy GM 216 235 6 Cyl. Engine 1937 - 1963 Timing Chain Cover with new seal installed and 55 to 62 GM/Chevrolet 3/8" Harmonic Balancer and Pulley $65.00
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Jerry, AKA Hotrod Lincoln was working on a small block dampener with big block pulley setup for a 235/261. Not for sure how it turned out.
| | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | I built one from a 6" diameter small block V8 damper, with a big block V8 2-groove pulley inverted over it. It requires the balancer hub to be shortened about 1/4" in a lathe, and a corresponding amount of material removed from the outside diameter of the hub where it meets the large diameter part. This allows the hub to be pressed back onto the crankshaft snout far enough to align one of the pulley sheaves with the water pump pulley. The other sheave can be used to drive a power steering pump and/or an air conditioner compressor. The cost of the new parts is about $125.00, plus machining. Jerry
