2 members (Jims46, Gray_Ghost),
176
0
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | My '53 Chevy has this strong thumping vibration as I get into the 30-40mph in 4th gear. I can't seem to get the truck to go over 42mph in 4th gear. It gets worse when I let up on gas. Is this a transmission problem? I have a floor shift 4 speed. The differential looks great. I re-did the drive shafts/universals. Also - who made these 4 speeds? This is a 53' truck with a 1961 235 - could it be a mounting problem with the older trans on newer 6? Ron | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 |
1963 c10 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That would be my guess too. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Sounds like a tire problem to me as well. The speed issue is more likely a different problem, perhaps a mis-adjusted clutch. The transmissions were more or less the same for the 4 speed, that shouldn't be an issue. They were a GM produced transmission, manufactured at the Toledo Ohio plant.
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Apr 2013 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 67 | I was thinking tire also - however, vibration nearly stops on acceleration and suddenly increases in intensity when I let up on gas. Seems like tire thumping would be related to speed only? | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Does the thumping go away after a few miles? If not it's likely not a tire. Bias ply tires flat spot when they sit leading to a thumping ride on cold start. As the tires warm up the flat spot goes away.
