Does the number on the engine block stamped into the boss to left of distributor
match the number that is on the riveted on plate, that is on the flywheel housing just beyond the starter?
The reason I ask is because the Hydra-Matic transmission and engine were matched at the factory.
Matching means: Flywheel Housing Alignment
(1) The flywheel housing rear hole is in the center of the flywheel and crankshaft. Within .004 of an inch. This is called Bore Runout.
(2) The flywheel housing rear face squareness to the engine. Within .003 of an inch. This is called Face Runout.
Read about it here:
FHA1 FHA2 FHA3 Illustration: Flywheel Housing & related parts What would happen is the engine would wear out.
They would find another engine and just throw it in without aligning the flywheel housing.
When the Hydra-Matic transmission would go thru the gears the truck would shake or vibrate, like something was out of balance.
Because they couldn't figure out what was wrong.
Some truck owners would pull out the Hydra-Matic transmission and put in a manual transmission.
Manual transmissions are a lot more forgiving.
You can easily ruin a Hydra-Matic transmissions with a flywheel housing that is not properly aligned.
That's why Chevrolet took the time to cast
This into the Flywheel Housing
