0 members (), 123 guests, and 5 robots.
Topics128,078
Posts1,056,035
Members48,433
#1066957 11/07/2014 3:56 AM
I'm having trouble finding Pistons for this motor at a reasonable price does any one know if there's any that'll interchange with it ? I think a 265 has the same bore but I don't know if the pin is the same size I need help thank you
Puryear #1066958 11/07/2014 4:08 AM
What's your idea of a "reasonable" price? There are several of them available on Ebay right now, new .040 and .060 oversize, for $27.50 each.
Puryear #1066965 11/07/2014 4:32 AM
That's reasonable I need 6 of them plus the rings, most sets I've seen for a 261 start at about 300
Puryear #1066967 11/07/2014 4:46 AM
It's surprising how much new or reconditioned stovebolt engine stuff ends up on Ebay. I shop for bargains there frequently, particularly when someone doesn't really know what their stuff is worth.
Puryear #1066973 11/07/2014 5:08 AM
Egge caries 261 pistons.
My Blog
Puryear #1067864 11/12/2014 5:24 AM
Q
Q Offline
Cheap cheap is not always the best way to go . I take quality at a higher price than cheap low quaility.And if you know exactly what you want then you look for the best price. Have fun!
Puryear #1067892 11/12/2014 12:59 PM
If the 265 is the same, summit has sets of 8 for under $200. With free shipping.
Puryear #1067913 11/12/2014 3:25 PM
Hollow65,
The 261 and 265 pistons are different part numbers. The diameters are the same, but the rings are different. Maybe the wrist pins are also different?
Puryear #1067921 11/12/2014 4:04 PM
Bummer, it would be nice to get some decent compression out of the inline 6's. Sounds like a lot of work, but might be worth swapping rods and all of it has to come apart anyway.
Puryear #1068000 11/12/2014 11:51 PM
What do you consider to be "decent compression", and why would it be necessary on an inline six designed to produce mainly low-RPM torque? 265 pistons have the wrong compression height, and the wrist pin is much larger than the ones the 235/261 engines have. The bore size is the only similarity.
Puryear #1068039 11/13/2014 1:48 AM
I've read that the inliners only had about 7:1. Another 2.5 points has to help something, no? I don't know the cc on the head, but that is really low compression imo. I was just curious if there was anyway to slap some better slugs in one of these engines? Didn't mean to flip the apple cart.
Puryear #1068042 11/13/2014 1:58 AM
The 1959 235 truck engine compression specification was 8.25:1; the 261 was 8.00:1
Good luck getting 9.5:1
Puryear #1068049 11/13/2014 2:26 AM
Mill the head?
Hollow65 #1068136 11/13/2014 3:39 PM
Originally Posted by Hollow65
Mill the head?
The intake valve/piston clearance is pretty close unless the valves are recessed the same depth as the milling cut, further compromising breathing. Flycutting the piston might be a possibility if someone just has to see lots of PSI on the compression gauge for some unfathomable reason. It's really not necessary on a stovebolt, and will probably cause destructive detonation due to the shape of the combustion chamber.
Let me respectfully suggest that you actually look at a stovebolt cylinder head sometime before continuing to propose unnecessary modifications.
Puryear #1068433 11/15/2014 12:57 AM
Crusing in the Passing Lane
I had the head milled .060" on my stock 302 GMC, made a significant difference, shimmed the rockers like amount.
EdPruss #1068685 11/16/2014 7:26 PM
1 Offline
The GMC and Stovebolt have much different combustion chamber designs than one another, and what works on one head doesn't cross over and apply to the Stovebolt. Cutting the Stovebolt head excessively requires sinking the intake valve by the same amount of the decking and really kills the airflow, negating any gains that might have come from the decking to begin with.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
Puryear #1069226 11/20/2014 2:31 AM
235 L6 pin: .865"
261 L6 pin: .927"
265 SBC pin: .927"
GMC & BBC pin: .990"
The V8 pistons are wayyy too short, big compression loss and no quench.
Shimming the rocker shaft up after milling keeps the pushrod angle correct (if it was correct before), but unless the intake seat is sunk the rocker geo to the stem will be wrong.
