4 members (Southerntruck, Phak1, DaveV, 2-Ton), 90 guests, and 2 robots.
Topics128,035
Posts1,055,566
This one is from out in left field.
I've snatched up a 1974 British Seagull outboard.
It's got a flywheel magneto, typical on most older small outboards.
Problem is, I tested the coil with an ohm meter between the spark plug lead and ground. Zero.
I don't know much about electrick-city, I found the above test on a YouTube video.
Can coils like this be repaired?
"Happiness equals reality minus expectations" - Tom Magliozzi
I guess in theory anything can be repaired, but sometimes it just not worth it. I would think you could find a mag energized coil off an old lawnmower or such to at least check that the coil is your only problem. I have found problems with the magnets in the flywheel which would lose 'strength' when hot and kill spark.
JimBow
Check out this site, I go there for all my antique engine and misc. information. They have a marine engine section.
http://www.smokstak.com/forum/index.php
