| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | This one is from out in left field. I've snatched up a 1974 British Seagull outboard. It's got a flywheel magneto, typical on most older small outboards. Problem is, I tested the coil with an ohm meter between the spark plug lead and ground. Zero. I don't know much about electrick-city, I found the above test on a YouTube video. Can coils like this be repaired?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I guess in theory anything can be repaired, but sometimes it just not worth it. I would think you could find a mag energized coil off an old lawnmower or such to at least check that the coil is your only problem. I have found problems with the magnets in the flywheel which would lose 'strength' when hot and kill spark.
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | JimBow Check out this site, I go there for all my antique engine and misc. information. They have a marine engine section. http://www.smokstak.com/forum/index.php | | |
