4 members (TGP, MikeStone1953, 51 3804, jmmmn37), 98 guests, and 3 robots.
Topics128,260
Posts1,058,322
Members48,485
I am looking for a harmonic balancer pulley for my 235 in my '58 Apache. The current one does not have a smooth pulley groove; looks like it has been plagued with rust and I think it is the root cause for premature wearing of the fan belt. Looked online with NAPA, AUTOZONE, Rock Auto and Advance Auto, no luck. I would appreciate if anyone knows where one is located and the best way to change it out without removing motor from the truck.
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
I would recommend pulling the belt, start the engine and smoothing the pulley with sand paper. You can run it for a minute with out overheating it. Pitting does not seem to affect a belt, but raised rust it tough on them.
Ebay is always a good place to start if you need to replace it.
My Blog
I do not know if your still looking but there is a guy on Facebook that has this If you have FB you might want to look him up Just FYI. I do not know him but he belongs to a group called Stovebolter's R'Us.
Andrew Pizano
November 12 at 8:29pm · Edited
Chevy GM 216 235 6 Cyl. Engine 1937 - 1963 Timing Chain Cover with new seal installed and 55 to 62 GM/Chevrolet 3/8" Harmonic Balancer and Pulley $65.00
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Jerry, AKA Hotrod Lincoln was working on a small block dampener with big block pulley setup for a 235/261. Not for sure how it turned out.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
I built one from a 6" diameter small block V8 damper, with a big block V8 2-groove pulley inverted over it. It requires the balancer hub to be shortened about 1/4" in a lathe, and a corresponding amount of material removed from the outside diameter of the hub where it meets the large diameter part. This allows the hub to be pressed back onto the crankshaft snout far enough to align one of the pulley sheaves with the water pump pulley. The other sheave can be used to drive a power steering pump and/or an air conditioner compressor. The cost of the new parts is about $125.00, plus machining.
